Beovision 5 serial number
This post has 9 Replies | 2 Followers
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Thu, Aug 22 2013 6:12 PM
Quick question please, can anyone tell me about a Beovision 5 with a serial number 16598720?
Thanks in advance.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Aug 22 2013 6:46 PM
It's one of the very first BV5's and will have the D5 panel.
Great TV, built like a Volvo. Chassis based on the Avant, so reliable - and the panel is a Panasonic commercial grade, so will last and last.
I can tell you more, but it's all boring! LOL
Lee
Chris Townsend
Qatar
Posts 3,531
Thanks for that Lee.
Will pass on it. It's up in Edinburgh with a stand for £200 if anyone's interested.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Aug 22 2013 7:06 PM
That's SUCH a bargain!
People are buying these for kids play rooms now. So what if they lick the screen when the Teletubbies come on, or toss the Wii remote at the screen by accident..  they're built to last and it's a cheap 42" TV !!!
Lee
Chris Townsend
Qatar
Posts 3,531
With the dreaded mother in law set to stay at my house longer, I'm trying to build a blokes bunker in my bedroom hence my pursuit of yet more technology. It's just for use with a sky box so if you think it's ok maybe I'll get it. Cheers
Mark
Malvern
Posts 381
Mark replied on Fri, Aug 23 2013 2:15 PM
Does the BV5 understand nMusic and nRadio? If it does, then it's quite desirable. If it doesn't, then it's a lot less so. I suspect that if it's an early version, then they won't be supported.
Mark
Mark
Malvern
Posts 381
Mark replied on Tue, Aug 27 2013 10:15 PM
Must remember to engage brain before asking question... what I meant to ask was "Does the BV5 understand the PC commands, for integration with the BeoMedia1?". However, I think that I've now found the answer - unless I'm mistaken, only the later versions of the BV5 do (Mk 4 onwards).
Mark
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Tue, Aug 27 2013 10:57 PM
Chris Townsend:
Wow!
Now that is a bargain! I'd like one!
Too long to list....
bramble
Posts 397
bramble replied on Wed, Aug 28 2013 12:00 AM
I was the buyer of the bv5, an upgrade from my bv3-32, as you would expect the build and picture quality is just as expected, buy a LED  LG or samsung.......think not !, M/L to the bs3000 + bl6000.......neighbours not best pleased Surprise
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Chris Townsend
Qatar
Posts 3,531
Can you post some pics when it's set up?
Regretting not getting it now....
Page 1 of 1 (10 items) | RSS
