Hi all,
I have acquired a Beocenter 2000 with Mirsch speakers that is in almost new condition.
There is however 2 little problems I've found and could do with some help. The left speaker inputs both run an awful lot quieter than the right channel and I'm not sure why. I have tried both speakers in both channels so I definitely know its a fault with the socket.
But the main issue is that the stylus arm seems to skate across the record almost as though there isn't enough pressure being placed on the disc.
I have checked the counter weight and think that it is set correctly but could a faulty cartridge be to blame?
Any help would be greatly appreciated as I'm a complete novice
cheers!
Callum
