Change the display on Beosound 9000
paddy2042
Newtown NSW Australia
Posts 210
paddy2042 Posted: Wed, Sep 4 2013 8:09 AM
I am trying to change the display on my Beosound 900 so that it always shows the track number as well as the disc.
The instructions state in the manual:
'The BeoSound 9000 display can give you three different types of information about the CD being played:
– Name*
– Number of CD and track
– Number of CD and elapsed track
time
To switch from one display to the other, you must press the OK button repeatedly while the CD is playing.
Switching between displays
Your chosen display indication for the CD player will remain in the display panel and only disappear temporarily when you undertake another operation on the BeoSound 9000 operation panel. Then the information which accompanies this operation will appear in the display for a short period of time.'
Mine will stay on the track number temporarily but always revert to the clock. Also it will not show the third option which is the time elapsed as stated in the manual also.
Any ideas.
Patrick
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Sep 4 2013 8:20 PM
Try pressing the "clock" button. It sounds like you have the clock turned on. Pressing once will turn off, again will turn back on.
Stan
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Sep 4 2013 8:21 PM
Stan
paddy2042
Posts 210
Thank you this seems to have done the trick. Your help is appreciated.
Patrick
Page 1 of 1 (4 items) | RSS
