As my Beo4 is in for repair. How do "back" on my spare Beolink 1000
try "stop"-button. Should work if I remember right.
regards, Adrian
no that unfortunately just stops the music on my Apple TV. Pressing stop again resumes the music. Any other ideas?
oh, sorry to hear. did you try "go to" + "stop"??
Sorry that one did not work either.
Not sure which model of Beolink 1000 you have but have you tried the various arrow buttons
Either the left single arrow or the downward solid white arrow may work.
Stoobie
I have the Mk3 model. Unfortunately no luck with any of the arrow functions.
Try 0 ( zero )
Best regards
René.
AdiS: try "stop"-button. Should work if I remember right. regards, Adrian
There was no BACK function in old BL1000 days.
It was possible to exit specific functions by pressing STOP.
But EXIT and BACK are not the same.
You can press EXIT on newer Beo4s by pressing BACK long.
Maybe this doesn`t help...:(
Stefan
