Hello everyone,
today i purchased a new playmaker as a wi-fi bridge. i am have it connected to my BeoSound 4 via a.Aux and the line in plugs. when i try to send music to it i receive the error message -15008.
Does anyone have any idea what is wrong and how i can fix it please?
3m3twinturbo:when i try to send music to it i receive the error message -15008.
how do you send the music (iTunes ?) and where do you see the -15008 error ?
BeoNut since '75
Dear Elephant,
yes, i am sending it via iTunes. the error appears on the iTunes screen when it is sent via the macbook and also the macbrook pro. when i send with my iPhone 4, the playmaker is there but it just drops out before playing, with no error message.
3m3twinturbo: Hello everyone, today i purchased a new playmaker as a wi-fi bridge. i am have it connected to my BeoSound 4 via a.Aux and the line in plugs. when i try to send music to it i receive the error message -15008. Does anyone have any idea what is wrong and how i can fix it please?
Thanks for the clarification that this happens from several sources with similar symptoms.
I don't have an Airplay but I did borrow one for a week and I do not recall seeing a message.
The Beoplay can't operate as a bridge like an Airport Express does -- the AE can be use to extend the range of an Apple base station.
The BeoPlay (I think only) is an edge device for driving a speaker or inputing in to an AUX socket of a Beosystem/Beosound/Beomaster.
I did not tested it with my Beosound 4 but it should have worked ....
Did you activate the Beosound 4 first by pressing AUX ?
Ahhhh (thinking as I type) now I think I think I know the problem - you connected the AUX out to LINE in ?
I believe the AUX in has to be connected to the BeoPlay's SPEAKER outputs - so the Airplay sound goes via the BeoPlay and into the BeoSound 4 as auxillary input: that's how my daughter in law uses her AE.
This means you may need a special cable - check the "Sounds Heavenly" advert below - there may be a description of what you want.
Or search for "powerlink to aux" ....
Thank you very much for your help. it is now working a treat. Playmaker connected to both the home Wi-Fi and physically to the Beosound 4 via AUX and then the sound out to the Beolabs.
