Lift System Issue
Raymond1947
Posts 2
Raymond1947 Posted: Sat, Sep 28 2013 1:36 AM
I just inherited a Beogram 4002 that appears to be in good working order - turntable speed, all operation buttons, lights etc.
The only problem is that the tone arm does not lift at all, when the Start button is pressed. The lift system just drags it across in either direction.   Can anyone suggest how to repair this?  Thanks
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I suggest that the lift/lower mechanism needs lubrication.
This is a well documented fault on the forum. Search this forum and the archived forum  for 4002 lubrication or similar and you will get plenty of help.
See here for  a very good article with pictures which details restoration of an identical turntable.
http://www.condoraudio.com/wp-content/uploads/Projects/BeoGram-4002-6000-Turntable-Restoration-Repair.pdf
Regards Graham
Raymond1947
Posts 2
Thanks Joey,   I print out some of these procedures and also find the service manual. Hope this works.  I'll let you know if I have any success.  Ray
joeyboygolf
Posts 4,188
Beware the flying circlips!!
If they ping, they are probably gone forever.
Regards Graham
Søren Mexico
Mexico City
Posts 6,411
joeyboygolf:
I call these circlips, Jesus Christ, because thats what I call out, when they fly away.Big Smile
Page 1 of 1 (5 items) | RSS
