The owners manual states the 4500 can be set to accommodate different types of equipment ( non B&O I assume )
Step 1 is to simultaneously press PROGRAMMING and #7.The display indicates OP and the appropriate cue, Tape2,CD,or Phono.
Step 2 is to touch Tape2, CD or Phono as the case may be.
I'm missing something here. I go through steps 1 and 2 but don't seem to be able to select anything different from what is pre set.
I am desirous of playing a B&O 3400 turn table with MMC 20CL cart. in the phono jack, a non B&O CD in the CD jack, and a non B&O TV in the TV jack.
How do I program for the above?
Many thanks in advance.
The programming functions for the sockets on the back of the Beomaster is mainly because B&O wanted to save some money by mounting fewer sockets (or maybe there wasn't space for more sockets). The Phono/TP2 uses the same socket. You can plug your Beogram 3400 into this - but you'll need a RIAA amplifier between the Beogram and Beomaster, as the 4500 does not have a build-in RIAA.You can plug a non-B&O CD player into the CD socket without having to programme anything (use the factory settings).- as you can also connect a MP3 player or any other device.You can also plug a non-B&O TV into the AUX/TV socket - (as you can plug almost any device to this socket). You only have to reprogramme for special options - e.g . IF you should want to plug a secondary tape-deck to the aux/tv socket and use the TAPE2 on the front panel or the remote control.
I hope this was helpfull.
Steffen:You can plug your Beogram 3400 into this - but you'll need a RIAA amplifier between the Beogram and Beomaster, as the 4500 does not have a build-in RIAA
That's an option because I have a BM4500 with build in RIAA.
Brengen & Ophalen
Leslie: Steffen:You can plug your Beogram 3400 into this - but you'll need a RIAA amplifier between the Beogram and Beomaster, as the 4500 does not have a build-in RIAA That's an option because I have a BM4500 with build in RIAA.
Yes - I remember that I got a RIAA module mounted in my first BM 4500, as i then had a Beogram 3300 (without RIAA). And when this module was mounted, the Beomaster should be programmed by pressing (touching ) 'Programming' + '7' - Option 'Phono'.
