3 years ago I bought a Beovision 7-40 from a reputable dealer in the West Midlands. They told me that the TV had had a full HD upgrade. Certainly when I views HD channels the picture was a lot sharper. The type is 9354 which was HD ready not full HD. I am now selling the TV and have been told by a potential purchaser that unless the standby light is white - not red - the TV has not been fully upgraded. Does anyone know if this Is true?
R
I have a vague memory that at one point the BV7 range changed from red dots to white dots
It would be before 2010
I did not like it, the red is iconic IMHO and I think that they may have then reverted back to red.
Can I suggest you post your serial number )except for say the last 2 digits) and someone wiser than myself may be able to narrow it down to a specific year/model/capability for you
BeoNut since '75
Hi cleveley and welcome to BeoWorld,
a MK1 made FullHD - I would doubt that.
They should have replaced almost anything - panel, board tuner....
It was probably made HDReady.
Has it got any HDMI's?
Are you watching from the internal tuner or an external?
In the last case: how is it connected to the tv?
The white dotmatrix came with the MK3, which was the first wirh BSys3 - a complete different BV.
http://archivedarchivedforum2.beoworld.org/forums/t/21087.aspx
Thanks for your help
Hi there thanks for advice.
If it isn't HD why would HD TV channels look sharper? What "HD Ready" actually mean.
There are no HDMI inputs on the TV. The HDMI cable from the digital box (Sky) is connected via an adapter into a SCART socket.
Thank you Ralf - that explains everything. When I bought the TV the salesman definitely said that the TV had been upgraded but maybe he meant to HD REady rather than full HD. It is true that even at a reduced "HD rate" - to that of the 1080 used by Sky - the TV has a much sharper picture. In fact it is as good as another Toshiba full HD TV I have. So yes you're right it's the actual picture that counts rather than the technical spec.
Thank you so much for your help.
