Beomaster 1900 and 2000 - multiplex tuning unit
neilmacindoe
Posts 5
neilmacindoe Posted: Mon, Sep 23 2013 12:18 PM
Does any one have any suggestions about where to buy multiplex tuning units for either Beomaster 1900 or Beomaster 2000? - I have both.
OR can you tell me if they are repairable?.
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
The auto fine tuning does not appear to be working. Sometimes flipping backwards and forwards between channels 'fixes' it but not always.  Sometimes the reception is static other times it is that a different station comes in, not the one that is pre set.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Sep 23 2013 12:35 PM
Both have a quite strong AFC function.
If a stronger station is very close to the preset station, the AFC can sometimes lock onto the stronger.
In these cases, it can be necessary to switch off AFC or deliberately preset the desired station just slightly off frequency
to the opposite side of the stronger station and then switch AFC back on.
If the tuner is drifting, that's a different story.
neilmacindoe
Posts 5
Hi Martin: Thank you – I will try that on the 1900, however, my 2000 doesn’t have an AFC switch – I guess it must be ‘always on’. If the tuner is drifting is it repairable? Are replacements available? regards Neil
Page 1 of 1 (3 items) | RSS
