Will it be possible to connect a CD player to a Beomaster 1900.
If so, to which port? Thank you
Yes, to the TAPE input.
The Beogram CD3500 is not a bad match - the CDX is another alternative but comes with RCA plugs so an adaptor is required.
Peter
