Hi,Im new to this forum so I didn't know where to post this. But my question is:I've bought a BV5 in silver/black and I want to change the colors of the aluminum panels to black, and the cloth to red. Does anybody know where I can buy the panels and cloth?
Not sure if the frames are still available. I changed my BV5 cloth from black to silver/aluminium.
Not an easy job because you have two separate two panels (fitted with double sided sticky tape) and put them back (after reclothing) in the exact same position.
Brengen & Ophalen
