I broke one of my BeoCom1 handsets and acquired a BeoCom 6000 handset to replace it (did not find any BeoCom handsets available). Is it possible to register the BeoCom 6000 handset with the BeoCom base? The handset briefly shows "Out of Range" then, when I put the base in registration mode and push the talk key on the hanset, the handset will beep in sync with the flashing of the red light on the base and then sometimes will say "search base," or something like that, or will simply stop beeping. Any advice?
Thank you
Sorry, the two phone systems are incompatible.
Welcome to Beoworld.
