Hiya Guys
wanted some suggestions of used second tv to go in the bedroom but having access to the TV downstairs
I use a BV3 attached to the BV5 downstairs - lovely picture and utilises the Sky+ box from downstairs. I used to use an LX6000 which also worked but which eventually bit the dust! The picture of the BV3 is far better than a BV6 or an early BV7 which would be the alternatives.
Peter
Peter: I use a BV3 attached to the BV5 downstairs - lovely picture and utilises the Sky+ box from downstairs. I used to use an LX6000 which also worked but which eventually bit the dust! The picture of the BV3 is far better than a BV6 or an early BV7 which would be the alternatives.
I echo Peter's comments about the Sky box. My BV10-32 does the same thing. I have two TVs connected to the same box, in different rooms, with both TVs able to control the box, via the Beo4.
A V1-32, BV10-32 or BC6-26 would do the same thing and are very cost-effective (for B&O).
