beocom 1401 wall holder
bidstonhall
Thailand 5560 miles from Struer
Posts 363
bidstonhall Posted: Sat, Dec 14 2013 11:06 AM
Hi all, picked up a beocom 1401 wall holder, the one with the audio and video buttons, my question is how do i open the little door that holds the batteries and also the second hole for wall fixing
it doesn't seem to want to move at all, i don't have instructions and don't want to damage it, cheers
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Dec 14 2013 1:30 PM
It is hinged at the top of the battery cover. You need a wide blade inserted at the bottom and tease it out. The wall holder takes three AAA batteries.
You need to get into the battery compartment to access one of the two screw holes for fixing to the wall.
Regards
Opman
bidstonhall
Posts 363
o.k. got it, had to use a thick knife, not the most obvious way of doing it, work perfectly of course, appreciate the reply
Page 1 of 1 (3 items) | RSS
