why a beolab 7 is more interesting than a bl 7.4 ?
This post has 11 Replies | 1 Follower
olvisab
Posts 1,391
olvisab Posted: Mon, Dec 9 2013 10:23 AM
Hi
I find 3 majors advantages to choose the beolab 7 instead of the beolab 7.4 as center speaker :
- when you don't want to use your subwoofer, you just have to select speaker 1 and you have stereo sound
speaker 2,3,4 and 5 options use always the subwoofer
- when your pair of front speakers become faulty, you still have a good stereo speaker left
- the bl 7.2 or 7.6 is more powerfull
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Ehlerz
Posts 51
Ehlerz replied on Mon, Dec 9 2013 11:55 AM
BUT...... The BL 7-2 does not have acoustic lense technology and does not perform as well as 7-4 in a surround setup.
/Ehlz
olvisab
Posts 1,391
olvisab replied on Mon, Dec 9 2013 12:56 PM
Hi
I had both and this is a very little difference if you can hear it in a surround set up.
Ehlerz
Posts 51
Ehlerz replied on Mon, Dec 9 2013 2:30 PM
Hi
I have had both aswell and disagree on the missing difference in a surround setup. I find the 7-4 much more suitable as a center than 7-2. IMO the sound of dialog is just much more crisp with the acoustic lense.
Agree on your other observations though, as an overall speaker the 7-1/7-2/7-6 are better suited.
/Ehlz
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Dec 9 2013 3:26 PM
olvisab:
I had both, a 7.2 and then a 7.4+BL9s. The 7.4+BL9 combination blew away the 7.2 in every way.
The first thing I noticed was the 7.4 enables conversations to be clearer, due to the centre and alt. The BL9s were amazing for movies. So, the perfect all-round combination.
Granted, the 7.2 is way better than the sound from a BV11, but the 7.4+speakers (BL3s, BL18s, BL9s etc) takes some beating.
BeoMegaMan
Posts 601
I have had all of them at one point in time (never the BL10), BL 7.4 wins the award by a lot if you have BL5's or BL9's. I found the lower 7's to be more than fine with say BL8k/6k.
Ah, you know... A little B&O here, a little there
olvisab
Posts 1,391
olvisab replied on Mon, Dec 9 2013 3:55 PM
moxxey:
I just said if your bl9 are faulty, your 7.4 alone will be ridiculous compared to the 7.2.
There is absolutely no comparison possible between the bl 7.2 and a serious pair of icepower/alt speakers.
But for the advantages I mentioned, the bl 7.2 or 7.6 is the best solution.
I heard a bv 11.55 (father's tv), I was however impressed.  But I couldn't compare it side by side with a bl 7.2
phult
Posts 51
phult replied on Tue, Dec 10 2013 11:04 PM
So on a related note. Do you think the 7.4 is the best center speaker that they make? Or is the 10 better.
I ask as I am looking for the best center to use with a projector. The center channel would be hidden behind the screen so looks don't matter.
P
phult
Posts 51
P
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Dec 11 2013 8:01 AM
phult:
Joined by the right alts (BL3, BL9 etc), the 7.4 is the best centre speaker in my opinion, yes. The 7.2 is probably the best as a standalone centre.
bayerische
Ekenäs, Finland
Posts 4,770
Although not exactly the same, but I love the mono alt speaker in my BV9!
Too long to list....
BeoMegaMan
Posts 601
phult:
I think they are darn near identical in my mind.
Page 1 of 1 (12 items) | RSS
