Sky commands from beo 4
This post has 10 Replies | 0 Followers
kpcvlp
Posts 27
kpcvlp Posted: Wed, Dec 11 2013 9:49 PM
Help needed again, got new beovision 5 with the newer beo 4  navigator. But don,t know how to control the sky from it. Worked some of them out but can't work out how to record .
 Does anyone have a list of instructions that would be great .
thanks Colin
kpcvlp
Posts 27
kpcvlp replied on Wed, Dec 11 2013 9:50 PM
In case it matters it's a sky + hd
MartinW
Posts 389
MartinW replied on Wed, Dec 11 2013 9:58 PM
Record is Menu 8. Tv guide is Menu 1. Info is Menu 5.
MartinW
Posts 389
MartinW replied on Wed, Dec 11 2013 9:59 PM
When you press Menu it shows you on the left what the commands are. Hope that helps?
kpcvlp
Posts 27
kpcvlp replied on Wed, Dec 11 2013 10:08 PM
Hi. Martin
thanks but we have the hd tv connected via the hdmi cable which wipes out the menu display also we lose the curtains and the volume and sourse display which I miss
MartinW
Posts 389
MartinW replied on Wed, Dec 11 2013 10:13 PM
Ah, you've got a DVI connection.
Ok, here goes then!
Go+1 is Tv Guide
Go+2 is Box Office
Go+3 is Options
Go+4 is Interactive
Go+5 is Info
Go+6 is Text
Go+7 is 'Sky' button (exit live pause)
Go+8 is Record - if not in TV Guide you may need to do this twice as it will only record when the banner is on the screen
Go+<<
Go+>> is fast forward - as above to go faster
Stop is pause and play.
MartinW
Posts 389
MartinW replied on Wed, Dec 11 2013 10:14 PM
A bit missing off my previous post...
Go+<<
MartinW
Posts 389
MartinW replied on Wed, Dec 11 2013 10:15 PM
Thats weird.... It missed off the rest my sentence again???
Go plus the rewind button is rewind - press rewind repeatedly to rewind faster!
kpcvlp
Posts 27
kpcvlp replied on Wed, Dec 11 2013 10:45 PM
Thanks Martin your a star
are you aware of any setting that I can get my curtains back and also the volume display or is it something I will have to live with
cheers colin
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Maybe the following will help
Regards Keith....
kpcvlp
Posts 27
kpcvlp replied on Thu, Dec 12 2013 12:03 PM
Thanks Keith
that's just what I need
Page 1 of 1 (11 items) | RSS
