Dear members,
I have three LC2s in my living room and encountered the following problem with them:
operating a single lamp 1 always operates another lamp simultaneously. Howeverm when I press lamp 2, nothing can be remote controlled at all and when I press lamp 3, I can remote control lamp 3 only. However, I haven't found a way to separately control lamps 1 and 2. No matter what I try, these two alway react simultaneously. How can I change that?
Thanks very much.
Rgds,
Kai
Problem solved. I just had to reassign numbers to the LC2s using the Beolink 1000. Don't know how this can be done using the Beolink 7000 though.
