The back has come away from the screen, how can I put it back togther??
Please help . it is nearly christmas ....
Dine it,
Unclip the cable grabber atht secures all the cables to the Beo5 to give yourself more cable to play with.
Then its all about getting the cables in the guide channles in the corrrect order feeding to the centre to enable the cables to feed back into the support mount.
Easy when you think it through.
