Beomaster 1500
This post has 11 Replies | 0 Followers
McDonnet
Posts 8
McDonnet Posted: Mon, Dec 23 2013 1:28 PM
Could anyone assist with how to make the radio work? Pressume I need to purchase B & O fm in room antenna from that period? Suggestions on where to buy most appreciated, ebay has not proven successful.
Many thanks
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Dec 23 2013 1:35 PM
FM dipole antenna are available on eBay with various fittings depending on the connections at the rear of the BM 1500.  Male and female connectors and antenna are available from QD Audio
 http://www.ebay.co.uk/itm/B-O-BANG-AND-OLUFSEN-COMPATABLE-FM-RIBBON-AERIAL-REF-AERIAL-/261314324344?pt=UK_Sound_Vision_Compact_Shelf_Stereos&hash=item3cd78c2778
and 2 pin connector types are freely available too.  Also at most hardware type stores or electrical outlets.
Unless you're after the 'rabbit ear' type which also come up on eBay.
Dave.
bidstonhall
Thailand 5560 miles from Struer
Posts 363
I listen to the radio on my beomaster 1500 every day, just plugged a little FM aerial i had handy, socket a bit like the TV coaxial socket , works great
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Dec 23 2013 2:08 PM
On many Beomasters a paperclip works just as well if you're in a strong reception area.
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Dec 23 2013 2:14 PM
And connect a pair of speakers and make sure, they are switched on at the front panel.
Søren Mexico
Mexico City
Posts 6,411
Here is mine
ouverture
London
Posts 263
ouverture replied on Tue, Dec 24 2013 12:14 AM
if you are in the UK, I can recommend this one - model SV9151, it is not retro though !
we are in a built up area with poor FM radio and this aerial sits by the window where the Beomaster is, the B&O aerial was just not man enough, but we bought the 9151 and now we get all the radio stations, it is an amplified antenna, which I think helps a lot too
http://www.amazon.co.uk/One-For-All-SV9151-Amplified/dp/B001R585R2
McDonnet
Posts 8
McDonnet replied on Tue, Dec 24 2013 12:21 PM
Thanks - will it plug in to the 1500 socket or does it need an adapter? WIll I need a separate MW aeriel?
ouverture
London
Posts 263
ouverture replied on Tue, Dec 24 2013 1:29 PM
yes it will directly plug into the FM coax connector on your 1500, this is because the One4All is really a TV aerial that happens to also be really good at pulling in weak FM radio stations
yes you will need another aerial for MW radio, if you are really serious about MW reception, have a read of this first, it was a real eye opener for me when trying to get MW radio for my Dad on his Beomaster 5000
http://www.marcspages.co.uk/tech/antmwrec.htm
and then you can decide whether to make your own MW antenna, there is a separate connector to use for MW radio reception on your 1500 (next to the FM coax plug)
ouverture
London
Posts 263
here is a pic of the aerial supplied by B&O for AM/MW radio reception, it is practically useless in the UK unless you are in a really good reception area for AM/MW broadcasts ( we are not )
ouverture
London
Posts 263
the tricky bit of course is getting the correct 2 pin connector for the MW aerial input on your 1500,  you may have to find a Maplins or old fashioned radio TV shop to get one, here is a photo
ouverture
London
Posts 263
ouverture replied on Tue, Dec 24 2013 2:40 PM
the amplified AM / MW antenna that B&O provided back in the eighties was called the Active AM Antenna AM10
http://www.beoworld.org/prod_details.asp?pid=1003
in fact there is one for sale on ebay  Item   321245630011
also, I know a lot of people have had success with TERK amplified antennas, they do a combined AM and FM aerial called the AF1 which works well
http://www.terk.com/radio-antennas/?sku=AF1
Page 1 of 1 (12 items) | RSS
