Beovision 6-22 and set top box
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Fri, Dec 27 2013 9:33 PM
Thinking of getting a 6-22 for the bedroom and currently got sky with magic eye which would work. When the sky box being used downstairs what can I use instead. Current tv (Samsung) got digital built In.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sat, Dec 28 2013 11:58 AM
Chris Harrison:
My 6-22 has a dealer programmable chip rather than the fixed STB-C list found in the TV menu of, for example, the BV5.
If you are buying a 6-22 ask what set top boxes are already listed on the TV, and either buy a STB to match or ask whether a dealer can add your preferred Freeview box. If you have a Beovision main TV you can set it up with both Sky and another Freeview STB and the link TV can choose the Freeview when the main TV is on Sky. Another way to add a different or later STB-C list is to link in an HDR-1 which has its own chip and can have its own IR blaster connection to the STB.
Graham
Page 1 of 1 (2 items) | RSS
