opening/closing broken
player not playing CDs - where can I get help -- Beocord 3300 tape player also needs help
Beogram CD3300 : first things first, replace the Philips blue cap on the servo PCB. Check solders in the PSU area.
Another possible problem will be the relay which can go wrong.
I had all three problems on mine!
The CD door: probably as simple as a new belt.
Do you have basic electronic DIYer skills?
Welcome to Beoworld!
Jacques
