Could someone offer advice. I have a Beovision 10 as the main TV and a Beovision 6 in a link room
There is a scart lead between the SKY box and the BV10 to provide video to the BV6.
The problem is that just recently the Yellow seems to have disappeared from the signal in the link room, this gives the appearance of the picture being over exposed, (light parts of the picture so bright the definition disappears , parts of the SKY channel selector being white instead of yellow).
I have tried using another scart lead between the SKY box and the BV10 but the problem persists. I have also connected the SKY box directly to the BV6 and the problem goes away.
The picture from the BV10 DVB is perfect so the coax between the BV10 and BV6 seems to be OK
Any suggestions on what could be the problem, would using the alternative scart connection on the BV10 work or are they just connected to the same circuit.
Thanks in advance
Tom
