I would really appreciate some help. I’v just got a BV 10 and am trying to set it up. I’ve connected the coaxial cable t oBV10 aerail and a hdmi cable between the digital box and BV hdmi A. The digital box is also connected to aerial and to internet with cable.
My problem is that I can’t tune any channels, either regular free to air digital ones or the ones I pay for. With my other tv, panasonic. i just need to find which TV’s hdmi is connected to thebox and then I set up the box usign the IR for the digital box. BV 10 doesnt seem to let you choose which of the hdmi sockets is connected to the digital box.
Any ideas about hwo I should install and tune the tv and box?
regards,
sia
https://www.bang-olufsen.com/~/mediaV3/Files/user-guides/beovision10/beovision10_guide_english.pdf
Thanks MM
