Beolab Penta III display
This post has 19 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Sat, Dec 21 2013 8:06 PM
Dear members,
I was taking a closer look today at a pair of Beolab Penta 3 in very nice overall condition sold by the original owner. However, on one Penta speaker, one pixel (maybe a column) wasn't working. Does anybody know what the reason might be and whether this can be fixed easily? Thanks very much!
Can the Penta III desplays be swapped with Penta II displays? I tend to like Penta II displays more...
Rgds,
Kai
Manbearpig
Posts 908
Forgot to mention: the speakers were linked to a Beosystem 2500. Is it necessarily the display that has a fault, or could it also be a problem of the Beosystem or the wiring?
Rgds
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Dec 22 2013 2:47 PM
If the display shows at least something, everything else is fine and the fault must be in the display module itself.
According to the service manuals the II and III displays have a completely different interface. The internal structure of the display module is not shown so there's no help for repairing it, but it might still be possible... anything from a dry solder joint to a blown driver component to a failed display element, impossible to say without taking a look.
--mika
Manbearpig
Posts 908
Thanks very much. Doesn't sound like an easy task. The speakers are cosmetically in superb condition. Better than the pair that I already own. However, the display error is something that really disturbs me. Very minor. Basically, there's one dot that is not correctly displayed. But if you know it, you always look there. If the seller were letting them go for a low enough price, that'll still be ok. However, he's asking quite a bit which will probably deter me from buying. Thanks again!
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Dec 22 2013 4:37 PM
tournedos:
Well not entirely true. The interface between the display controller card and the speaker are identical. So a MKII display unit with its controller cards will work in a MKIII speaker. Could be difficult to find a complete pair of MKII display units though.
Regarding the weak or missing dot in the MKIII display I would think is a bad solder joint.
//Bo.
A long list...
Manbearpig
Posts 908
The display in your avatar is a MK2 display, isn't it? I like it better since it matches the Beolab 5000 display much better and has the additional items "Source" and "Track" on it.
Rgds, Kai
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Dec 22 2013 6:01 PM
Yes its the MKII display. I also like it better.
//Bo.
A long list...
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Dec 22 2013 7:07 PM
BO:
Yes, I see the confusion now - for some reason, I was thinking about the interface between the actual display module and the controller board. You could of course swap them both over.. if they fit mechanically, I dunno.
--mika
kammeri
Posts 49
kammeri replied on Mon, Dec 30 2013 12:57 AM
Gentlemen,
The display PCB's in the II's and III's are (as previously mentioned) in fact very different, the II being the more sophisticated one with an ambient light LDR etc. The connection from the amplifier to the PCB, however, is almost identical.
I just tried to swap the entire display units from our III's into the II's, but for some reason they don't seem to work. Vice versa it would require some cutting on the connectors, which I'm not willing to do. Has anyone got an idea what the reason could be? All displays work fine on their respective speakers.
Regards!
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Dec 30 2013 4:24 PM
Strange, if you look at the schematics it should work.
//Bo.
A long list...
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Dec 31 2013 8:42 PM
The mk2 can be swapped with mk3's. Only some mechanical changes. The processor boards are different. So are the displays of course.
The missing dots are not repairable. I've seen several displays by occasion which missed some dots. The problem wasn't cracked solder joints, unfortunatly.
Maybe the switch at the bottom was set wrong?
Sometimes you have to take off the powercords to make the displays working again.
Don't forget that the mk2 displays can't be placed behind mk3 glasses. They become unreadable. Or hardly visible.
kammeri
Posts 49
kammeri replied on Fri, Jan 24 2014 8:43 PM
I just swapped the mk2 display back into one of the speakers to troubleshoot the inoperability of the mk3 displays. Strangely enough, now even the mk2 displays have stopped working, which worked fine previously.
The Pentas are hooked via PL mk2 cables to a BeoSystem 2 (Penta selected in the menu) with the speaker switches set to video. I even checked the fuses, which were intact. Could there be something more in the settings of the BS2, that could have changed by accident? Otherwise I am fresh out of ideas.
Beobuddy
Posts 3,972
Beobuddy replied on Fri, Jan 24 2014 9:39 PM
Fully wired MK1 cables are normally used with the penta. These are thicker than the mk2 version. But then again, with mk2 cables, the penta wouldn't switch on...
WalkingPossession
Manchester
Posts 360
I'm sure it is the Mk.2 PL cables that are the fully wired (and therefore necessary for the Penta displays).
It is the Mk.2's that are the thicker cables, whereas the Mk.1 & Mk.3 are much thinner versions.
Michael
WalkingPossession
Manchester
Posts 360
Michael
Dave Farr
France
Posts 2,283
Dave Farr replied on Sat, Jan 25 2014 5:13 PM
Correct, as explained by Lee in a previous post:
Powerlink cable suitability for speakers;
Mk1 are for non IcePower speakers (for example the BeoLab 6000, early BeoLab 4000, BeoLab 8000)
Mk2 are for everything and can also carry data signals, so are perfect for BeoLab Penta.
Mk3 are for IcePowered (for example BeoLab 8002, BeoLab 6002, BeoLab 3)
Dave.
kammeri
Posts 49
kammeri replied on Sat, Jan 25 2014 8:57 PM
In this case the cables are not the culprits, thus the same cables have been in use for half a decade with the displays working.
Last time the Mk2 displays stopped working was due to dried out capacitors on the pcb. They were renewed four years ago and I doubt they would cause the malfunction this time.
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Jan 26 2014 9:55 AM
kammeri:
If the displays are removed from the speaker without the Pentas completely disconnected from both mains and powerlink, the LCD itself maybe damaged. I know that from my own (bad) experience,
//Bo.
A long list...
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Jan 26 2014 7:34 PM
Or placed the connector upside down the wrong way?
Sometimes a total reset (back to standby and back on again) will help.
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Jan 26 2014 7:37 PM
I got lost in which type of mk's powerlink cables. The earliest versions were very thick and looked the same as din-aux cable with a diameter of almost 8-10mm. Just to point out that the thinner versions will not work with the penta or beolab 5000 etc. These lab's need both pin 1 and 4 driven.
Page 1 of 1 (20 items) | RSS
