On my BV11 I have programmed 4 turn stand positions and stored them 1 through 4 with names. When I select TV it turns to position 1 and when I select DTV (with XBOX connected) it stays position 1. If I program DTV to stored position 4 as I would like, it turns to position 4 when DTV is selected. The problem is that when I select TV, it also turns to position 4 and not 1 as I would like. When I select my BS5 (RADIO, CD or Spotify via AMEM) it turns to position 2 as it should, so this is not affected. Can you not program 2 different positions on the stand for DTV and TV (VIDEO sources). It seams like they alway must have the the same preset stand position.
It seams unlogic with 9 programable positions on the stand, and they can't be stored to different sources and must be selected manually every time you select a source which is VIDEO related.
Henrik
