I just recently picked up a Beomaster 1900 in good working order.
So far, I am unable to find any information online as to whether it will work with an MM cartridge.
Does anyone know if you can play an MM turntable through the 1900?
Thank you
Congratulations on picking up a BM1900 - I have one myself. Yes, MM cartridges will work with the BM1900. Although I have no personal experience with MC cartridges with the BM1900, I do not believe they would work with the BM1900 without an additional step-up phase between cartridge and receiver.
If using a non-B&O turntable you may need an adapter cable.
Great,
Thanks for that!
