Hello
I have a BM5/BS5 setup as audio master with spotify.
On the same ML network, I have 2 linked rooms. I can listen to N.RADIO and N.MUSIC without any issues on them, but not Spotify.
Is there a restriction or do I need to change something ?
Christophe
Spotify should work in all link rooms - at least it does in my setup. Spotify can even wake me up in the morning via BV7 timer.
Usually Spotify is assigned to source A.MEM. Does your link products (what are you using?) respond to A.MEM?
If your link stations don`t respond to A.MEM, assign Spotify to another source as CD or....
Hope this helps.
Stefan
Hi
I also have Beosound 5/master at home and I have presently one link room.
I can listen to spotify using A.MEM. A.N.RADIO works for netradio and A,N.MUSIC I use for beosound library itself,
Regards
David
Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
Thanks all
A.MEM did the trick !!
Next time for me, RTFM !!
Have a nice day
