Hey I am in the market for 2 used Beolab 3. I want to ask you if anyone knowes when the accustic lense was changed from plastic to aluminium.? Have anyone knowledge from what serieno.?
I want of course to buy to used ones but with alu lense. Is there a mark II or III, and from what year of produce.
Trucker
All BL3 lenses is made from plastic. Only the top plate is aluminium. That goes for all BL3
Is that the same for all produced beolab 3. I Thougth the first years of production the top was plastic too. Are there some else differens between produkt from 2004 or product 2013.
Thank you all for your answer.
I'm also considering getting a pair of Beolab 3 iso my Beolab 8000, just because I need some space in my living room. I hadn't found so far why there were different versions (Mk1 to Mk3).
Does anyone know the differences, which version should be first looked for?
By the way, is it possible to have them converted easily from 110 V to 220 V when returning to Europe?
Thanks for sharing.
