The connectors are probably quite expensive and that is a bit on the high side. Steve at Sounds Heavenly is a bit cheaper and it includes shipping:
http://soundsheavenly.com/masterlink-control-and-sync/35--mlblack-.html#/length-15m
Things like decent quality HDMI cables are also silly prices but you get what you pay for. Cheap alternatives are almost never as good..
Dave.
I can only agree with you. The fact is that I have about 30 m of ML cable left from previous installations, but they are split in 5 to 9 m lengths... that's why I'm a bit reluctant to spent 80€ from something I already have but in different pieces
Yes, indeed I have at least one connector box left. Will try it.
If you know how to solder a short ML cable can be easily extended with an ethernet cable.
