Morning all
the title says it all really, the version on Beovision is late 7-32, with HDMI sockets and no DVD
The questions, if it's the chassis, and it's going to be over £1k to repair, which I cannot afford, what should I replace it with, my thoughts are a second hand 7-32 screen from the inter web or would a 7-40 fit the same stand ? It's a motorised stand and the speaker is a 7.4, so to replace it wil have to be a 7 series really.
Which version of the 7-40 did a really big picture upgrade occur? Was it mark 3 ??
I realise the later the version the better, but I recall a fairly big upgrade in mark 3.
Advice appreciated !
Andy
The stands are different, and the bracket for the Beolab 7.4 won't work on a 7-40 stand. The 7-32 stand is a single pole, the 7-40 stand has two poles.
x:________________________
AndyM: Which version of the 7-40 did a really big picture upgrade occur? Was it mark 3 ??
MK4. The MK4was a huge upgrade over the MK3, which was the first 1080P panel and very dark. I had a MK3 for a while, then two MK4's.
Hmm, ok, so it will have to be a 32 if I get a replacement then! Oh yes, I also have a mini mac connected as well as sky and a blue ray player !
Cheers moxxey, but it looks lie I might have to stay with a 32, btw I am just up the road in weston super mare ))
Hi Andy, what are you going to do with the broken BV7 ?
regards Douglas C
