I've tried for hours but I can't tune the TV. When I plug digibox to my other B&O there are no problems. Has anyone got help on how I can check my setup please. I have scart into B&O from the digibox, when I press TV I can't go up the channels. thanks Kenny
Hi. Which scart connection is your scart plug connected to? If my memory serves me when looking directly at the rear of the tv there are 3 in a row and you need the leftmost connection. Bizarrely this is called the v tape connection in the menu. Are you using a digi box that is compatible with the inbuilt set top box controller? Incidentally I assume you are using the sat button on your Beo4 and not the tv as tv is only for analogue signals and pretty much phased out throughout Europe now. Through scart the tv should not need any tuning, it should pick up the signal straight away.
Graeme.
