Best powerlink cable to fit under the BeoMaster 4500 cable cover
This post has 1 Reply | 0 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Sat, Feb 8 2014 3:09 PM
I've having difficulty getting my cable cover to fit on my BeoMaster 4500. I'm using 2 powerlink mk3 cables, and it's just too tight of a fit to attach the cable cover. Has anyone found a powerlink cable that has a shorter and/or more flexible head that allows for the cable cover to fit? Perhaps a powerlink y-splitter helps? I'm interested in other BeoWorlders' experiences and solutions.
beojeff
USA
Posts 2,012
beojeff replied on Sun, Feb 9 2014 4:15 PM
I've solved the problem by using a B&O powerlink y-splitter. While the ends seem to be of the same length, the end of the y-splitter cable is more flexible. It's possible that the MK3 cables that I have are not official B&O cables.
Page 1 of 1 (2 items) | RSS
