Update Firmware (Bluetooth) B&O Earset 2
This post has 3 Replies | 2 Followers
tirolervierkantholz
Posts 5
tirolervierkantholz Posted: Sun, Feb 16 2014 11:16 AM
Hi there
 I have a B&O Earset 2. No I want it to use with an Samsung Galaxy S4. Does anyone know where I can get an update for the Firmware (Bluetooth) for the Earset 2?
Thanks for your answers
Regards
Ron
BeoMegaMan
Posts 601
BeoMegaMan replied on Sun, Feb 16 2014 11:29 AM
The last update that was available only corrected issues with the iPhone 3GS. There are no more updates or support for the ES2.
Ah, you know... A little B&O here, a little there
tirolervierkantholz
Posts 5
Hello BeoMegaMen
Thanks for your Information. Do you know if there is a patch for the Samsung Cell Phone to use the ES2?
Regards Ron
BeoMegaMan
Posts 601
BeoMegaMan replied on Sun, Feb 16 2014 11:59 AM
There is no patch or support for the ES2 from B&O. I know of none either from Samsung or any other manufacturer. If you absolutely have to use the ES2, look for equipment that support older bluetooth standards 1.1 and 1.2. Bluetooth is 4.0+ ATM.
Page 1 of 1 (4 items) | RSS
