Hello,
I have two Beocom handsets. The tip that plugs into the wall socket has broken off one end, exposing the electrical connections.
Anyone know how i can find an easy solution to fixing this?
I would speak to Steve @ Sounds Heavenly -he's a B&O specialist and maybe able to provide you with a suitable cable.
Regards
Noel.
TarikG: I have two Beocom handsets. The tip that plugs into the wall socket has broken off one end, exposing the electrical connections. Anyone know how i can find an easy solution to fixing this?
If you're referring to the two red connectors, then they look like car type crimp connectors and were probably used to reconnect the wires after passing through a wall or hole in cabinet. If the part connected to the handset has exposed wires it should be straightforward to reconnect using similar crimp connectors or even some terminal block. If you know someone who is handy with a soldering iron then they could be soldered and then covered with heatshrink. You just need to observe the colours of the wires.
