Beosound 5 ripper, track data but no artwork?
This post has 1 Reply | 3 Followers
wortonmiller
Posts 18
wortonmiller Posted: Mon, May 12 2014 9:59 PM
Hello all,
my beosound cd ripper that used to work perfectly, has, in the last 3 weeks, decided to rip the cd, get the track data but not get any artwork. The last 3 or 4 CDs I've ripped have got everything but the artwork! Any ideas?
thanks
Edoardo
San Marino
Posts 163
Edoardo replied on Wed, Oct 8 2014 11:29 PM
Dear Wortonmiller,
What you said is only a part of the problems I have had ripping all my CD's.
I also replaced that device (in guarantee, of course), 'cause it suddenly stop working and there was no way to extract the CD inside.
When even the second ripper was broken, I decided to not replace anymore it, and since them I am ripping the CD's with Windows Media Player, that is more quick and accurate.
Infact I realized that the track titles and album titles were full of errors, to correct manually.
Don't worry if the BS5 does not always find the artworks; it's sufficient search with google the title of the album and it will find the artwork in more resolutions.
On this issue, I do report to you what my reseller told me when I purchased the BS5: to choose artworks with resolution up to 500x500 pixels.
The BS5 works properly even with higher resolutions artworks, but if you want to command the BS5 with a mobile phone or tablet using the Beolink app, you will wait so long time while the device is carging the artworks......
see you!
Page 1 of 1 (2 items) | RSS
