Connect a Beolab 3 MK3 with a Powerlink MK2 cable ?
This post has 9 Replies | 1 Follower
l_avocat
Switzerland
Posts 28
l_avocat Posted: Tue, Feb 18 2014 3:12 PM
I use a non-B&O pre (Emotiva UMC-200) and the trigger adapter RCA -> Powerlink from Av-connection. With my Beolab 4000 it works!
I'm looking for Beoalb 3 to change the old 4000. But Beolab 3 needs a Powerlink MK3. And I have a Powerlink MK2 cable plugged onto the av-connection adapter.
I read this "This is because Mark III contains an additional voltage reference wire intended to prevent background hum." (http://beophile.com/?page_id=13249)
And B&O write in the Beolab 3 User's Guide: "Do not use any of the old type of Power Link cables, as this will cause noise, and thus not give optimum sound quality!" And in fact, when my Beolab 7-4 turn on with your trigger adapter (without any music) I hear a little noise (shhhhhh) in the tweeter…
May I use the MK2 Powerlink cable onto Beolab 3 ? Or should I DIY a connector with a system-mass (blue) on PIN 7 ?
Thanks a lot for any advice
Samsung PS64F8500, Beosound 9000, 2 x Beolab 1, Beolab 7-4, Beolab 2, 2 x Beolab 4000, Beolab 3500, 2 x Beo 4, Emotiva UMC-200, Oppo BDP-103D, Panasonic DMR BCT-730; Harmony Ultimate.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
According to this thread you can.
Tayne
Posts 38
Tayne replied on Tue, Feb 18 2014 4:12 PM
Mark 2 cable will work fine. Just don't use Mark 1
l_avocat
Switzerland
Posts 28
l_avocat replied on Tue, Feb 18 2014 4:33 PM
That's right... Thanks a lot because this thread didn't appear when I searched.
Yes we can! I quote here the answer: you can use MK2 cables for connecting Beolab 3 MK3:
9 LEE:
Mk1 and Mk3 are the same thickness (i.e. thin !!) and it's the Mk2 which are pretty thick thanks to being fully wired & shielded.
Mk1 are for non IcePower speakers (for example the BeoLab 6000, early BeoLab 4000, BeoLab 8000)
Mk3 are for IcePowered (for example BeoLab 8002, BeoLab 6002, BeoLab 3)
Mk2 are for everything and can also carry data signals, so are perfect for BeoLab Penta.
Lee
w5bno123
London
Posts 578
w5bno123 replied on Wed, Feb 19 2014 3:36 PM
I believe it is recommended to use original B&O MKIII PL or fully mounted PL as it reduces the noise in the audio signal built up in the switch mode power supply. The extra cable reduces noise on the data ground, blue cable pin 7.
l_avocat
Switzerland
Posts 28
l_avocat replied on Wed, Feb 19 2014 4:49 PM
How should I do, when my source is a non-B&O preamp: Emotiva UMC-200.
I use the 7.1 RCA outputs, with each the trigger adapter RCA ->PL of av-connection.dk... ? http://www.av-connection.dk/?ML=2126
w5bno123
London
Posts 578
w5bno123 replied on Wed, Feb 19 2014 11:00 PM
l_5F00_avocat:
Sorry I didn't read your original post properly.
Try this, cut off the PL end and strip the cable back use the green as the positive and the green/white with half the outer screen as the negative for one phono plug.
Use the brown as the positive and the brown/white with the other half of the outer screen as the negative for the other phono plug.
DoubleU
Posts 562
DoubleU replied on Thu, Feb 20 2014 5:40 AM
I wouldn't cut it... The adapter cable you use now has no white/green and white/brown wires. It's not a network cable!
This adapter cable should already have pin7 shortcutted to pin2. Just swap your BL4000 with the BL3. You'll be fine!
w5bno123
London
Posts 578
w5bno123 replied on Thu, Feb 20 2014 12:43 PM
DoubleU:
You are right! What I was writing about applies to network cable, doh! However what I did write about is true when using BeoLab 14 for example with a non B&O AV receiver at line level., this cures any hum off the receiver.
l_avocat
Switzerland
Posts 28
l_avocat replied on Thu, Feb 20 2014 1:36 PM
w5bno123:
It's interesting for me... Can you just explain what should I do for a cable/adapter to do this? What do you have to do when connectin a non-B&O receiver with RCA/CINCH pre-out audio outputs? After all my existing central 7-4 also theorically needs PL MK3... Wink
Page 1 of 1 (10 items) | RSS
