Hi, I just purchased a Beogram 4004 on CL that is not working. It's probably going to need lots of TLC but there's one issue that needs to be fixed first. The white plastic pulley on the drive motor does not lock mechanically onto the motor. It just spins freely on the motor shaft. This is the later model with the small pulley.
The pulley was originally glued to the motor shaft.You will have to glue it back on using f.e. Araldite or similar strong glue.Remember to wipe the motor shaft with IPA or acetone to remove grease etc. before glueing.
Martin, thanks so much for your answer. That's a relief to know that there aren't any missing parts. I'll have some time to work on the TT next week and will post my results. Best regards, Rob
