Hi! My Beomaster 4500 keeps switching on spontaneously to CD mode. It happens all the time when it is off, when it is playing a tape or phono mode. Any thoughts? I've tried to hide the remote in case it is sending IR beam, switch the whole beosystem off but unsuccesfully
Joan
Problem sorted! I left the Beosystem switched off for 12 hours and now works perfectly again.
What a mistery!
The time honored cure for a lot of tech problems !
