I have a Beocenter 1 that has been damaged by flood and have been asked by insurers to get a cost for replacement and original purchase price, we bought it in 2004 I think?
Hi Trudi,
Sorry to hear about your flooding.
You don't say where in the world you are located, but original cost for Beocentre 1 in the UK was a little over 3000GBP I believe.
With regard to replacement cost - is it on a new for old basis (ie replacing with the modern equivalent) or are you looking to replace with a used Beocentre 1?
Martin.
Sorry to hear you were flooded, hope you get it sorted out quickly.
look at the articles tab on the main page there is a price lists by year the beovcentre 1 from 2004 was £3100 so could do a print out from there as well for them
Thank you , this is very helpful!
Thank you for your reply, very helpful, will print off.
