Ethernet port on a 7-55
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Fri, Mar 28 2014 9:56 AM
Just floundering around trying to setup up my new 7-55 and i note there is an Ethernet port. Mentions in the handbook about automatic updates.
Can anyone confirm that if i connect my 7-55 to my router by Ethernet, then it will receive updates automatically?
Regards Chris(its massiveYes - thumbs up)
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Mar 28 2014 10:06 AM
Hi Chris,
with the ethernet port you can only update the software of the internal bluray player and use Bluray live (if supported by Bluray).
You cannot update the software of BV 7-55 itself, this can only be done by dealer.
Regards
Räuber
BeoMegaMan
Posts 601
BeoMegaMan replied on Fri, Mar 28 2014 12:45 PM
The Ethernet port on the 7 series is for Blu-ray interactive support and to update the Blu-Ray sw only. Not the whole chassis as with the new Sys4 based products.
Ah, you know... A little B&O here, a little there
Page 1 of 1 (3 items) | RSS
