Beovision parts
Bjorn
United Kingdom
Posts 35
Bjorn Posted: Thu, Mar 20 2014 11:53 PM
Does anyone have a list of semiconductors and components for the PCBs on the beovision MX4000?
I noticed that there isn't a list in the schematics.
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Mar 21 2014 8:07 AM
If you happen to have one of the late Beo4 models, look on site under MX7000 and you'll find a much better service manual for the entire model family. Most of the differences are in software, so it should be helpful with the earlier models as well.
--mika
Bjorn
United Kingdom
Posts 35
Bjorn replied on Fri, Mar 21 2014 7:29 PM
Thanks for your answer, it wasn't until after posting that I realised there was a more updated service manual. I have 2 beovisions in at the moment. My old MX4000 which is unwell, deflection and power supply failure; and the replacement which happened to get dropped by the courier. All powers up, but the deflection is off, sending the set into standby. I'm guessing the impact has damaged a couple of parts.  The original aim was to replace my TV as I don't like working on them, but looks like I'm going to have to repair both TVs. As I'm ordering components for one, I might as well order for both.
 I should know by now, that sticking a "FRAGILE" or "HANDLE WITH CARE" label on well packed boxes, only encourages mishandling. Next time I should have put "KICK ME!" labels on instead. :)
Page 1 of 1 (3 items) | RSS
