BEOMASTER 4400 AFC problem
Maciej Zietara
Krakow Poland
Posts 3
Silver Member
Maciej Zietara Posted: Tue, Oct 16 2018 11:32 AM
Hi everyone,
I am restoring right now Beomaster 4400, I recap all electrolytes, and the beast came alive, no signal current are set  - sounds beautiful!
Phono 1 and 2 works perfectly, FM also tune nicly with stereo. I found out one problem with AFC and I am stuck.
In FM mode when I swith on AFC function it mute both chanels, even with strong stereo signal. I can tune the signal but ther is a shift in comparison to (AFC OF) and the volume is decreased around 8 times when AFC is ON.
I have checked conections on AFC button (77 and 80) seems to be ok,
and also tranzistors TR7, TR8 and TR9 they are all good.
Any idea... suspections, experiences.. ? wich might be helpfull.
Regards,
maciej
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 16 2018 12:43 PM
The AFC function is strongly related to the muting circuit.
The button is labelled AFC-ST, where ST stands for Silent Tuning (muted between strong stations).
Most of the problems in these areas are caused by wrong wattage tuning discriminator lamps.
Maciej Zietara
Krakow Poland
Posts 3
Silver Member
Thank you Martin, I will try to play a bit with this area.
maciej
Maciej Zietara
Krakow Poland
Posts 3
Silver Member
Hi Martin, you were right, I have changed the bulbs and it works perfectly.
Thank you,
maciej
Page 1 of 1 (4 items) | RSS
