Hello - I have a complete 3300 system and was lucky to find a wall bracket for the amp/tuner, and cassette as well as the CD and turntable. I am looking to assemble this and wall mount it so that the set can look like the one that is in the old advertisement. Would anyone know about the assembly instructions for this? Many thanks#
Prof D
Professor David A Flynn JP LM
Hi David,
if you have all of the pieces it should be fairly evident. Maybe this post on the old archived forum will help:
http://archivedarchivedforum2.beoworld.org/forums/t/19081.aspx
This old eBay listing shows how it goes:
http://www.ebay.com/itm/Bang-Olufsen-Beomaster-3300-Beocord-3300-Wall-Bracket-Raritat-/252023808420?nma=true&si=V4dDS5QJDUb7SX0kU%252Bc5yVCG%252F9E%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Dave.
