Hi all,
S'been a long time!!
I have a basic
BV 6-26 sw 5.0
Type 9352
Item 181....
S n 1867....
Recently had some power cuts, the tv is not code protected, but after said cuts it is now behaving strangely in that it seems to randomly go into stand by mode.
There are no visible(programmed)shutdowns etc, tried various things to cure this situation all to no avail.
The tv is linked to an Ouverture, can't remember master /slave situation, will try later!
My question is, how do I re establish factory default status? - can't find anything on the menu lists!
I work on the KISS principle - Keep it Simple Stupid
I am not at home right now but the 'reset' funtion is somewhere in the Service Menu, which itself is accessed from SETUP using button presses 0 0 Go. Then go to 'monitor service menu' and reset is at the bottom of the list.
Thanks Guy
Thought it was in there somewhere, I'll give it a whizz later and hopefully all will be back to 'normal'?
Thanks for your speedy response, as ever the site is a wonderful tool!
salut
Ok, so far so good!!
Again, many thanks
