Hi Beoworlders,
I've just got a pair of Beolab 4000 floorstands, but I don';t know how to attach the speakers to the plastic brackets..
There's no manual onsite, do I use the wall brackets somehow? Or am I missing something?
Thanks in advance
x:________________________
You need to attach them to the wall brackets. These have to two parts. The bottom part is mounted on the stand. The top part is mounted on the back of the Beolab 4000s. Then you clip the speaker with this back part into the bottom part on the stand. At least that's what I remember doing last year.
Greetings,
Kai
A word of caution about the power link cables. The stands are designed for you to run the cables inside the stand. However, this is very difficult, and it's extremely easy to damage the power link cables when running them through the stand. I prefer to leave my cables running outside of the stand.
