Wireless 1
This post has 6 Replies | 2 Followers
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
joeyboygolf Posted: Wed, Apr 16 2014 1:12 PM
Anyone know if a pair of wireless ones can be used in the same room as the system without employing an IR eye.
For example BS3000 in a large room with BL8000 and no speaker cables from the 3000 to the 8000's.
Regards Graham
tompa
Posts 64
tompa replied on Wed, Apr 16 2014 5:44 PM
Sorry, but No you can see wireless1 as a beolink Active cut in 2 parts masterlink in one and powerlink in the other so you need ir Eye to turn on your bl8000
joeyboygolf
Posts 4,188
tompa:
Thanks tompa
Regards Graham
StUrrock
Posts 995
StUrrock replied on Wed, Apr 16 2014 8:26 PM
Wireless 1= mans nipples = useless
BeoMegaMan
Posts 601
When set to a fixed channel the Wireless 1 is as excellent and reliable as ML. The problem is very few people have it set to fixed channel. It's not the greatest for use with MLGW as well it can't be given a network address.
Ah, you know... A little B&O here, a little there
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Apr 18 2014 3:04 AM
BeoMegaMan:
How do you set it to fixed channel?
Jeff
BeoMegaMan
Posts 601
By using the service tool and master link jig. Your local dealer can supply you if he feels up to it or you can have a tech come out and do it for you.
Page 1 of 1 (7 items) | RSS
