Beomaster 3000-2 Phono Input Problem
harrion
Santa Fe, New Mexico, US
Posts 3
harrion Posted: Tue, Mar 27 2012 11:55 PM
Greetings folks, I'm new here and could use a little sage advice.  I have two Beogram TTs, A TX and TX-2 and the above Beomaster (all amazing yard sale and thrift store scores), and I love all three, so I'm very happy this site exists.  One of the two RCA phono inputs on the receiver works perfectly, and the other is not getting preamplification, it's only functioning as a regular line level input.  Anybody out there have a similar issue, or any insights into what the problem may be? Is this a common issue in this receiver? Any help appreciated.
Step1
Manchester, UK
Posts 1,268
Step1 replied on Wed, Mar 28 2012 12:13 AM
there is no issue, I assume it was designed for turntables with a built in line level RIAA amp. Purchasing a later Beogram (4500, 6500 7000) with built in amp would be an option or an external phono pre amp.
Olly
harrion
Posts 3
harrion replied on Wed, Mar 28 2012 12:29 AM
Step1, thanks for the quick reply.  Let me just make sure I'm on the right page.  So, You're saying, even though Phono Input 1 does contain internal preamplification, Phono Input 2 was designed to give the user the alternative to use a player with it's own built-in preamp or with an external preamp.  This is very good news and makes sense, in light of the existence of Beograms with built-in preamps.  BTW, do you have any idea of where I might find a free viewable copy of the user manual for this receiver?
Søren Hammer
Denmark
Posts 953
As Step1 explained, the second phono input is for ceramic cartridges (for old 78 RPM decks!), it is essentially just an auxillary input. You'll need a RIAA preamplifier or a simple switch to get both turntables online Smile
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
harrion
Posts 3
harrion replied on Wed, Mar 28 2012 12:39 AM
Thanks Soren.  Got it! You guys made my day!
Søren Hammer
Denmark
Posts 953
harrion:
No problem, just here to help! Smile
Brendan Cameron
Melbourne, Australia
Posts 9
Hi Soren,
You mentioned that the Phono 2 input on a Beomaster 3000-2 "is effectively just an auxiliary input". Would it be safe and useable to connect something such as a Sony TV using that input?
Regards, Brendan.
Søren Hammer
Denmark
Posts 953
Brendan Cameron:
Hi Soren,
Regards, Brendan.
Hi Brendan,
You can connect any line level source to the Phono 2 input without any problems - from iPods to TV's.
- Søren
Page 1 of 1 (8 items) | RSS
