Beolab 3500 software update.
This post has 20 Replies | 3 Followers
Bundy
Posts 67
Bundy Posted: Tue, Apr 22 2014 7:48 AM
Hi
From other treats I have read that I can update my Beolab 3500 SW 1.1 to 3.33 by changing a PCB board. Where can I buy this board, and is it easy to change?
Brgds Mogens
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo replied on Tue, Apr 22 2014 11:26 AM
Take a look here Big Smile
Stoobie
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Apr 22 2014 12:17 PM
Maybe worth to know which update you want? do you really need sw 3.3? It`s the latest update for MLGW compatibility. Or do you want N.MUSIC and N.RADIO instead of PHONO and A.TAPE2 shown in the display?
Maybe someone has a sw 2.X chip, who doesn`t need it because he just upgraded to 3.X...?
Stefan
Bundy
Posts 67
Bundy replied on Tue, Apr 22 2014 3:54 PM
Hi
I understand it has to be the sw 3.3 if I what to activate a.aux on the Beosound 4 from the Beolab 3500.
Mogens.
Bundy
Posts 67
Hi.
Well It looks simple.
Mogens
frog
Camberley UK
Posts 624
frog replied on Tue, Apr 22 2014 5:34 PM
It is - but not sure where to get the new 3.3 s/w. I'm also keen to get MLGW support on some 3500s I have.
Iceman10245
Berlin - Germany Nova Santa Ponsa-Islas Baleares
Posts 186
I am also interested very much. My dealer wanted to have approx. 400€ for the rebuilding
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass,  BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence ,  BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white,   Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
mjmedlo
Posts 922
mjmedlo replied on Thu, Apr 24 2014 11:11 PM
I've done it on one years ago.
Not complicated at all
Bundy
Posts 67
Bundy replied on Fri, Apr 25 2014 6:10 AM
Sounds Great, but where can we buy the kit? My local dealer wont sell spareparts.
mjmedlo
Posts 922
mjmedlo replied on Fri, Apr 25 2014 12:14 PM
Are you in the US?
Bundy
Posts 67
Bundy replied on Fri, Apr 25 2014 7:07 PM
No, Denmark
mjmedlo
Posts 922
mjmedlo replied on Fri, Apr 25 2014 7:15 PM
I can't help there friend.
TWG
Posts 1,672
TWG replied on Sat, Apr 26 2014 4:17 AM
what are the benefits of added MLGW compatibility for the Beolab 3500? Is every Beolab 3500 usable as a powerlink speaker with the update?
lano
Posts 161
lano replied on Sat, Apr 26 2014 8:30 AM
TWG:
Hi, what are the benefits of added MLGW compatibility for the Beolab 3500?
It can receive light and control signals from a remote and pass them on to the MLGW. You can still control the Beolab 3500 from MLGW without the update.
TWG
Posts 1,672
TWG replied on Sat, Apr 26 2014 1:17 PM
Thank you. Is there an opportunity to let a Beolab 2000 receive light and control signals with the MLGW, too?
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Apr 26 2014 3:05 PM
I don't now if my answer is relevant to your question:
Asked my dealer a while ago (again) if my Beolab 2000 could be upgraded to accept 'A.AUX' from the IR-command. This time he contacted B&O and told me: there is no software update availlable for the Bl 2000 as it was with the BL 3500.
So I keep on pushing my bedrooms BV 3 into A.AUX and then walk to my bathroom to push the 'ON' button of my Bl 2000 in the bathroom. Embarrassed
Keeps my health in shape Crying
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
TWG
Posts 1,672
TWG replied on Sun, Apr 27 2014 12:38 PM
Thanks Chris, for the B&O fitness tips ;-)
I know that the Beolab 2000 are old, but it would be nice to upgrade their functionality. I guess there are more than enough of them sitting some where in homes waiting to arrive in the 21st century. :-)
Millemissen
Flensborg, Denmark
Posts 14,680
Chris - you have a 'BeoSport' in your house Big Smile
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Apr 27 2014 8:26 PM
TWG:
Indeed, its such a very fine sounding loudspeaker, fits so nicely in a lost corner of my bathroom...
Millemissen:
Forget to mention: after switching the BL2000 on, I first have to go back into the bedroom to put the BV3 off. Hé,Hé. Lives easy with ML....
Dear MM and TWG, I can still go to the fitness afterwards, Beer
I really have to make some time changing the configuration of my ML and use the line-in of my new NL/ML converter. This would reduce all those steps to activate the sound coming from my Mac mini on the BL2000.
Removing the Mac mini from A-AUX on the BS3200, and configure the Mac mini on the NL/ML converter line-in input to VMEM (would be V-Tape button for the BL2000). And best of all, it would perhaps upgrade sound on the ML chain, putting one section (BS3200) out of this chain. I guess Line-in on the NL/ML converter injects the analog signal more or less directly into the ML-cable.
beolion
Posts 485
beolion replied on Sun, Apr 27 2014 9:23 PM
Hi
Does anyone know which commands the bl3500 and 2000 accept with the different versions?
Ie a.aux, v.mem, dtv etc
Chris
Ostend-BE
Posts 1,170
Chris replied on Mon, Apr 28 2014 4:09 PM
beolion:
Hi
Keith has already given the answer and info about the latest actual SW3.3 for the beolab 3500 including the commands, take a look at the old forum http://archivedarchivedforum2.beoworld.org/forums/t/36474.aspx
SW1.1 is till today still the actual software for the Beolab 2000, witch means there is no A-AUX button.
I am sure that B&O could bring the BL2000 to the same level as the BL3500, but age of the appliance and part price for the complete renewal of the PCB1 board, would not be a commercial step for the factory and to costly for customers. The microcomputer is located on PCB1, witch is a main board in the BL2000, as the microcomputer PCB36 in the BL3500 is only a small part.
I am using a BEO4, witch gives me the possibility to use all the normal buttons for daily use (tv, radio, V-mem, A-mem, dvd…). But I cannot use any of the added commands, as is A-Aux.
Listening to A-Aux is only possible with pushing the play-button on the BL2000 or mute-button on the BEO4, but A-Aux must already being started and playing somewhere in the ML link.
Hope to be of some help.
Page 1 of 1 (21 items) | RSS
