I am new to B&O world. I recently brought BeoVision 11 with Beo4 remote and I would to know what kind of sources need to add in order for Radio to work. Are the radio functions in-built to TV and can I make it work? Also, I am trying to use P-AND-P function make it work but for some reason it TV complains that combination doesn't work. So I tried using Youtube (built in App) with TV, which are not the combination of two HDMI sources but doesn't work.
Note: There are some limitations when using the Picture-and-Picture (P-AND-P) function since some source combinations may not be possible. For example, you cannot watch two HDMI sources or two coded channels at the same time. When an invalid combination is selected, an onscreen message appears on the television screen.
Any tips on using Beo4 for daily use are greatly appreciated. Thanks for your help.
Radio is only as broadcast through satellite or Freeview. Connect to Freeview and, assuming you have correctly tuned the TV, you will be able to call-up a radio menu in similar format to the TV programme menu.
You cannot stream internet radio through the TV's web browser. The best way to add internet radio is to add an Apple TV.
Graham
