BV10 - Speaker volume setting vs distance setting
Marcello
Posts 213
Marcello Posted: Sun, Apr 27 2014 7:14 PM
This might be a silly question, you are warned.
My right speaker (one of two BL 6000) is further from the TV than the left one (+ ~1m to the listening position). The difference is noticeable.
I have seen that there are two settings in the TV which can be altered: the individual volume of the speaker and the distance.
What is the right way to proceed? I have set the proper distances  but it is not enough. Should I raise the Right volume or decrease the Left one? Or for some reason changing the distances alone should have fixed the issue?
DMacri
United States
Posts 881
DMacri replied on Mon, Apr 28 2014 11:17 AM
The distance affects the timing of the audio signal, but not the level. You should use a signal level meter to make the volume level adjustment.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (2 items) | RSS
